Billiboi Posted June 6, 2009 Report Share Posted June 6, 2009 Hi all, i have just been validated woo . Thanks.Went to ramsgate with a few lads today and had severe freewheel porblems. I have a freewheel that has the 4 prong removal thing. A guy in Addicted bike shop broke his remover and im just wondering if anybody knows how to get it off another way, before i attack it with my saw etc Any advice welcome, i really dont want to have to buy a new crank Cheers allAlso if i do need to replace my crank, whats the difference with these as i cant see any apart from the name?, cheershttp://www.themontyshop.com/index.php/driv...rank-arm-r.htmlhttp://www.tartybikes.co.uk/product.php?pr...category_id=515 Quote Link to comment Share on other sites More sharing options...
sstein Posted June 6, 2009 Report Share Posted June 6, 2009 But the tool?Or you could put the freewheel in a vice, crank it up so it crushs the bearings and then just turn the crank. Quote Link to comment Share on other sites More sharing options...
Billiboi Posted June 6, 2009 Author Report Share Posted June 6, 2009 Ill try the crushing idea let you know how it goes.What did you mean by "but the tool"?Cheers man Quote Link to comment Share on other sites More sharing options...
Nickkkkk Posted June 6, 2009 Report Share Posted June 6, 2009 (edited) What did you mean by "but the tool"?Cheers manbut the tool? hmm... using my davinci code skills i think this reads....... BUY THE TOOLEdit: it better had do or i'm gonna look a tit...Linky Edited June 6, 2009 by Nickkkkk Quote Link to comment Share on other sites More sharing options...
sayshell Posted June 7, 2009 Report Share Posted June 7, 2009 (edited) this is easy! As long as you don't care if you destroy the freewheel. You only want to save the crank right? See those 2 holes on the freewheel? They are the lockring you can ususally get them loose with a hammer and pointy thing it just unscews. Undo that pull out the pawls and clamp the freewheel piece down in a vice. Next part you need a frame. Look for an old frame you don't need anymore saw off the top tube. Put the crankarm inside the toptube and use this to spin it inside the vice so you have mad leverage. good luck. Make sure you turn the right direction hehe remember the freewheel will be upside down in the vice if you do it this way. Edited June 7, 2009 by sayshell Quote Link to comment Share on other sites More sharing options...
Billiboi Posted June 7, 2009 Author Report Share Posted June 7, 2009 Cheers, thats the answer i was looking for.If i am looking at my freewheel from the back of the crank, which way must it unscrew? is it clockwise?Thanks Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted June 7, 2009 Report Share Posted June 7, 2009 Cheers, thats the answer i was looking for.If i am looking at my freewheel from the back of the crank, which way must it unscrew? is it clockwise?ThanksI think it's clockwise but just try, you can't really go wrong. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted June 7, 2009 Report Share Posted June 7, 2009 I think it's clockwise but just try, you can't really go wrong.It's anticlockwise. cause think clockwise tightens it up cause you pedal clockwise so stick it in a vice and turn anticlockwise. Quote Link to comment Share on other sites More sharing options...
Billiboi Posted June 7, 2009 Author Report Share Posted June 7, 2009 Cool cheers, here goes!. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 7, 2009 Report Share Posted June 7, 2009 this is easy! As long as you don't care if you destroy the freewheel. You only want to save the crank right? See those 2 holes on the freewheel? They are the lockring you can ususally get them loose with a hammer and pointy thing it just unscews. Undo that pull out the pawls and clamp the freewheel piece down in a vice. Next part you need a frame. Look for an old frame you don't need anymore saw off the top tube. Put the crankarm inside the toptube and use this to spin it inside the vice so you have mad leverage. good luck. Make sure you turn the right direction hehe remember the freewheel will be upside down in the vice if you do it this way.Why would you chop up a frame? Frame tubes are only 2mm thick at the most, and they're made of aluminium so I doubt it will be strong enough.Just use a big steel tube over the crank arm, or hit it with a soft nosed hammer. Quote Link to comment Share on other sites More sharing options...
