Cross Overs
Andrew Willis
I think you have to heat the ends of the crossover pipe up. Like put it in boiling water for a bit so it makes them more soft and flimsy, put them on the barbed fittings and your away.
I think this is how you do it but i am not 100% sure.
Hope this helped, Elliott.
That won't work. The hose is too brittle/hard to be affected by the heat. Use those magura blocks. OR find two blocks of wood and clamp them together, drill a 5mm hole in the centre of the blocks then clamp the hose in the hole with about an inch sticking out the top and hammer the barb in.
when I make crossovers I dip the barb in some dot4 fluid to make it a little easier to go in. Then I get some needlenose pliers and try widen the hosing ever so slightly. Then when Im tapping the barb in a always check to see if the barb is going in straight to reduce the chance of the cable splitting.
EDIT: I dont even use a vice!! :S Dont own one so I have to use mole grips and a corner step
Edited by RossMcd
Cross-Over pipe
you will need - hosing, 2 barbs, pliers, file, hammer, vice, wood.
1. Cut the hosing to length with a pair of pliers. Hold it next to an existing cross-over to accuratly measure it.
2. Get two pieces of wood that will fit in your vice. the ones i use are about 30x70x100mm
3. Grab a file (or anything that will indent the wood) and make a triangular shaped impression down the middle of both pieces of your wood. This impression is the guide for the hosing which keeps it in place when tightening the vice and when the barb is being hit into it.
4. The blocks are finished. Put them in the vice with the hosing through the middle making sure there is just short of an inch of hosing sticking out of the top.
5. HARDEST BIT: now it's just a case of hitting the barb into the hosing. (the hitting part of the hammer should be softer than the barb you are hitting so it dosn't fold the barb in). Now repeat the process for the other side, i think i messed this up about three times ha ^_^
hope this helps (Y)
Edited by Nickkkkk
Cross-Over pipe
hope this helps (Y)
what do u mean a triangular impression in the wood :P
cheers
andy
