Onza T-vee 2005
On most mod's the front wheel is 20" and 19" on the back ,but on a Onza T-Vee the back is 20" i was just wandering when i upgrade it ill proberly get a 19" would it run ok?
No if the frame is designed for a 20" the brakes will not fit a 19" in less it has disc brake mounts.
If you can upgrade the frame to a 19" design then it will work of course.
Hope that helps you mate.
He right, the brakes won't line up properly. You'll have to upgrade the frame and rear wheel at the same time. It's better to spend a little bit more money and get a better onza.
(Y)
(Y)
Yeah go for a second handd tpro or a new pro (Y)
Edited by LukasMcNeal
You will be best off saving your money for a while and buying a new or second hand bike which already has a 19" back wheel on it. That way it will upgrade pretty much everything on the bike and it will be much easyer. It could possibly have magura brakes on it aswel if it is second hand and that is always a bonus :)
Im proberly going to still get the onza but im coming in to some money at the start of july so ill upgrade a lot of parts but already have pedals grips and freewheel, but im very happy i had lots of advise but ideally i want a trials bike asap but soon ill change the backwheel and frame.
Hey :)
Your Bike Would Posserbely Not Work If You Fitted a Rim Which Was Rong Size Because The Brake Clamps Would Not Be In The Right Place So You Would Find When You Ride Your Onza The Brakes Would not Be Up To The Standard They Was Before
Hope That Helps Mate Good Luck! ;)
