stunt man t Posted June 2, 2009 Report Share Posted June 2, 2009 my head-set has just become realy wobbly when i went to turn the bolt to tighten the top cap it just spins and wont get any tighter or any looser and now i cant take the top cap off, which ever way i turn the bolt it just spins and dont do anything any ideas what i can do?? Quote Link to comment Share on other sites More sharing options...
trials ryan Posted June 2, 2009 Report Share Posted June 2, 2009 Sounds like you need a spacer in it, thats all. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted June 2, 2009 Author Report Share Posted June 2, 2009 (edited) Sounds like you need a spacer in it, thats all. but i cant get the top cap off to put one on??the stem cant come off untill i get the top cap off Edited June 2, 2009 by stunt man t Quote Link to comment Share on other sites More sharing options...
trials ryan Posted June 2, 2009 Report Share Posted June 2, 2009 (edited) but i cant get the top cap off to put one on??the stem cant come off untill i get the top cap offMay not work but does the olt pull up, if so pull it up and try to get some of the thread in the star nut, if its not that mabey your head set and frame is warped (means the wratteling has caused the frame to expand) ?If all that fails try this http://www.trials-forum.co.uk/forum/index....p;#entry1897530 It worked but it took alot of messing around but me and my bro did it in the end. Edited June 2, 2009 by trials ryan Quote Link to comment Share on other sites More sharing options...
austen Posted June 2, 2009 Report Share Posted June 2, 2009 Your star nut will be f*cked. Could either be the whole star nut spinning in the steer tube or just the silver threaded bit. Try sticking a long screwdriver up the steer tube to hold it in place and loosen the bolt. If that doesn't work stick a metal bar or bit off wood up the steer tube and hit it with a hammer and it will hammer the star nut out! you'll need to buy a new star nut though! Quote Link to comment Share on other sites More sharing options...
stunt man t Posted June 2, 2009 Author Report Share Posted June 2, 2009 May not work but does the olt pull up, if so pull it up and try to get some of the thread in the star nut, if its not that mabey your head set and frame is warped (means the wratteling has caused the frame to expand) ?no mate the bolt go up it just turns, but makes a horrid grinding noise, maybe the star nut is just turning in the steerer tube???ill use the drill method i think cheers xYour star nut will be f*cked. Could either be the whole star nut spinning in the steer tube or just the silver threaded bit. Try sticking a long screwdriver up the steer tube to hold it in place and loosen the bolt. If that doesn't work stick a metal bar or bit off wood up the steer tube and hit it with a hammer and it will hammer the star nut out! you'll need to buy a new star nut though!think youre right matebut i got a new star nut so all is good Quote Link to comment Share on other sites More sharing options...
trials ryan Posted June 2, 2009 Report Share Posted June 2, 2009 (edited) no mate the bolt go up it just turns, but makes a horrid grinding noise, maybe the star nut is just turning in the steerer tube???ill use the drill method i think cheers xLol! mabey i wasnt such a fool after all, trust me it works though.think youre right matebut i got a new star nut so all is good Edited June 2, 2009 by trials ryan Quote Link to comment Share on other sites More sharing options...
