Damon W Posted June 2, 2009 Report Share Posted June 2, 2009 basically, as many know my frame is in bits, and i might be able to lend a frame off my mate, but its a 26" frame and iv got 24" wheelsdoes any company make adaptors to convert 26" 4 bolt magura mounts into 24" 4 bolt magura mounts? essentially would just be a plate with mounts further down?any expected problems with this idea? Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted June 2, 2009 Report Share Posted June 2, 2009 Geo would be a it weird no ? I know Heatsink Steve has some "26-"24 adaptors i enquried about, think he wanted liek £15 ? Only problem is there Vee but you could use evo mounts/a vee for the time being. Quote Link to comment Share on other sites More sharing options...
Damon W Posted June 2, 2009 Author Report Share Posted June 2, 2009 Geo would be a it weird no ? I know Heatsink Steve has some "26-"24 adaptors i enquried about, think he wanted liek £15 ? Only problem is there Vee but you could use evo mounts/a vee for the time being. no, the marino i had was gu geo, jus had 24" wheels ive just been told edd potts is the man to talk to? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 2, 2009 Report Share Posted June 2, 2009 should have kept that other marino really... Quote Link to comment Share on other sites More sharing options...
Steve-A Posted June 2, 2009 Report Share Posted June 2, 2009 4 bolt booster, bolted to 4 bolt mounts and jubilee clipped at end. Brakes mounted using 4 bolt mounts, upside down. 2 or 4 bolt booster to ad a bit of stiffness. If you snap jubilee clips you can tie the brake on with v brake cable. Job done Quote Link to comment Share on other sites More sharing options...
Damon W Posted June 2, 2009 Author Report Share Posted June 2, 2009 (edited) should have kept that other marino really...yer yer iv lernt my lesson , but wer not goin into that AGAINdont go off topic please 4 bolt booster, bolted to 4 bolt mounts and jubilee clipped at end. Brakes mounted using 4 bolt mounts, upside down. 2 or 4 bolt booster to ad a bit of stiffness. If you snap jubilee clips you can tie the brake on with v brake cable. Job done cheers il forward that to who ever i try get to make me one, wat booster is that? leeson? an problems with it? Edited June 2, 2009 by Damon W Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 2, 2009 Report Share Posted June 2, 2009 haha was only messin Quote Link to comment Share on other sites More sharing options...
Steve-A Posted June 2, 2009 Report Share Posted June 2, 2009 Yeh was a Leeson booster. Ran fine, save for snapping one of the jubilee clips mid ride and having to tie it on with a bit of spare brake cable. It was a pure bodge, if the option is there to buy one of Heatsinks v mount kits and use evos that would probably result in a better brake I'd have thought. Quote Link to comment Share on other sites More sharing options...
Damon W Posted June 2, 2009 Author Report Share Posted June 2, 2009 Yeh was a Leeson booster. Ran fine, save for snapping one of the jubilee clips mid ride and having to tie it on with a bit of spare brake cable. It was a pure bodge, if the option is there to buy one of Heatsinks v mount kits and use evos that would probably result in a better brake I'd have thought.why did the jubilea clip snap? i would of thought there was no stress on it?and i thought jubilea clips were strong?i threaded many frames and jubilea clipd them with no problems Quote Link to comment Share on other sites More sharing options...
mr kenny Posted June 2, 2009 Report Share Posted June 2, 2009 Damo, i found these a while ago and never got round to buying a set to look at to see if that would work...http://www.identitibikes.com/identitibikes...php?id=FMID666Zkenny Quote Link to comment Share on other sites More sharing options...
