Some Dickhead... Rb Problemo!
Simpson
Basically I trusted some people to take care of my RB and its kinda blown up in my face and come back with a raped bleed hole, where water i just pissing out the sides of the bolt... what are my options... so far I have thought of 3 options.
- f**k it off... I've got a spare 04 lever body so can just put the RB lever in there and be done with it.
- Try and use a treadlock when doing the bolt up hoping it will just help to seal the gap? then bleed the rb through the piston, which is hasstle but oh well.
- Try to arildite it shut? Will this stand up to the back pressure?
Tried Ptfe tape?
http://www.tapes-direct.co.uk/index.php?ma...csjvklksqimce25
Being 28p its worth a shot, in case you don't know what it is, Ptfe tape is used by plumbers to wrap around the threads to stop them leaking, Do this to the bleed bolt and i recon it will work.
Edited by Connor Powell
Tried Ptfe tape?
I was about to say that.
There is also some kind of silicon (forgotton it's name, mabye a plumber on here could help) that plumbers use to make the threaded ends of radiators more water tight. I don't know what kind of pressure it would with stand though.
Well radiators must have a lot of pressure?
Problem with that is that the end of the radiators threads match, Simps's problem is that the whole that the bleed screw has been made bigger so the putty might not work, With ptfe tape you can wrap more on to the thread to keep it tight, if you see what i mean :)
Sorry I didn't write the whole of what I was going to say :P. I work with a plumber when he need's abit of help and he uses both the ptfe tape and the silicone stuff, he told me why he does it but I can't remember, so I was going to suggest that you try both together If just the tape on it's own fails.
The tape (mentioned above) is really good, it partailly stopped my crank arm from coming loose so a tiny bolt will be fine.... I think.
Edit:
0.55 (Y) Edited by Nick pyke :)
Defo give the PTFE tape a try first. Potentially a cheap and quick fix. Hydraulic brakes are low pressure so it may work.
Otherwise, Loctite 577 is the thread sealant I would use (works for higher pressure set-ups and you'll still be able to get the bleed screw out when you need to), although not worth buying just for one job since it will cost around £15 for a bottle!
Steve
Ok sweet, cheers for the help Steve, got some locktite in the garage also but ill try the tape first.
I love my dads mine field garage sometimes :P
have they just lost the ball bearing that sits inside :ermm: ? If they have, get 1 out an old freewheel, fit a treat :).
Josh.
Josh.
Acctually, not sure if they come with a ball bearing, might well of been a bodge :P, so try wackin a ball bearing in there, will give you a perfect seal aslong as its clean.
Josh.
Oh, and if this works, make sure to take a few out with you, 'because if you bleed your brake when your out nd about, your gauranteed to loose the lil thing (Y).
Yeah theyre meant to have a ball bearing in there, if its missing then thats probably the reason its leaking. Other than that they havent cracked the body by trying to tighten the bleed screw up too much have they?
No bodys not cracked... ball bearing? :S
If you could, if we ever meet, I would let you fertilise me.
Saturday at abingdon? :)
edit: I was wrong its 4.75mm according to my trusty mitutoyo verniers :D
I would be happy to bet that its a 3/16" ball bearing, the o-rings in RB levers are imperial so no reason why the ball shouldnt be :)
3/16" = 4.7625mm btw.
Edited by forteh
