Jackibrap Posted May 31, 2009 Report Share Posted May 31, 2009 I looked on tarty bikes needing to buy a new b.b and im not sure which size will fit the onza blade. The two sizes are .119mm axle and 127.5 axle?????? thanks Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted May 31, 2009 Report Share Posted May 31, 2009 What crank/fw/bashring set-up are you running ? Quote Link to comment Share on other sites More sharing options...
George.E Posted May 31, 2009 Report Share Posted May 31, 2009 I looked on tarty bikes needing to buy a new b.b and im not sure which size will fit the onza blade. The two sizes are .119mm axle and 127.5 axle?????? thanksId say that for the Blade you are running a front freewheel ?Well id go for the 127.5 as you have the longer axle for the freewheel. Quote Link to comment Share on other sites More sharing options...
Jackibrap Posted May 31, 2009 Author Report Share Posted May 31, 2009 Cheers. i just wasn't sure. Thanks. Quote Link to comment Share on other sites More sharing options...
