Mission Prodigy Trials. Posted May 28, 2009 Report Share Posted May 28, 2009 hello everybody,I am wondering if anybody know's how to remove standard swiss-stop black pads from plastic backings so I can fit my new heatsink Cnc backings . ? Quote Link to comment Share on other sites More sharing options...
Technical Tom Posted May 28, 2009 Report Share Posted May 28, 2009 But them in the oven on about 200 degrees for about 10mins, but just keep checking regularly. Then get 2 pairs of pliers and simply pull the pads apart from the backings. Quote Link to comment Share on other sites More sharing options...
Mission Prodigy Trials. Posted May 28, 2009 Author Report Share Posted May 28, 2009 But them in the oven on about 200 degrees for about 10mins, but just keep checking regularly. Then get 2 pairs of pliers and simply pull the pads apart from the backings.Thankyou Tom I will try that later but is their an easier way to remove them eg using soap or a chisel or screwdriver. Quote Link to comment Share on other sites More sharing options...
Technical Tom Posted May 28, 2009 Report Share Posted May 28, 2009 You could just try and pull them apart with 2 pairs of pilers, depends how well they're glued in. Best bet though is the oven trick mate Quote Link to comment Share on other sites More sharing options...
mr_malcolm Posted May 28, 2009 Report Share Posted May 28, 2009 If you have just bought some cnc backings why not get some new pads to put in them aswell instead of standard black pads? Quote Link to comment Share on other sites More sharing options...
Mission Prodigy Trials. Posted May 28, 2009 Author Report Share Posted May 28, 2009 You could just try and pull them apart with 2 pairs of pilers, depends how well they're glued in. Best bet though is the oven trick mate Il try both methods thankyou googled it but just websites that sell Magura Hs33 rim brakes. Quote Link to comment Share on other sites More sharing options...
Rob L Posted May 28, 2009 Report Share Posted May 28, 2009 Another Idea is to boil them in water for about 15 mins. Quote Link to comment Share on other sites More sharing options...
JT! Posted May 28, 2009 Report Share Posted May 28, 2009 Another Idea is to boil them in water for about 15 mins.Yeah, that's a bit safer with plastic backings. Quote Link to comment Share on other sites More sharing options...
Heatsink Posted May 29, 2009 Report Share Posted May 29, 2009 The answer is here Steve Quote Link to comment Share on other sites More sharing options...
