Rounded Top Cap Bolt
trials ryan
easy way place the alen key into the bolt, tap the top of the allen key slightly for a fe seconds. It will make the allen key make a slight hole further down.
Hope this helps (Y)
may work...
or try a torx head in the next size up and whack it in.
i usually find a tight fitting torx bit and hammer it in so it grips the allen key head or undo your stem bolts jam your wheel between your legs and turn the bars to losen it off enough to undo. hope this helps.
