Maggie On Vee Mount
TrialsMan Dan
A mate of mine who used to ride trials said to me that i could still put a HS33 on my bike even though it only has mounts for Vees. He said it would move about slightly and i may have to get a booster. Has anyone done this and if so, is it okay like that? I'd really like a maggie because my current vee is on its last legs.
Any advice welcome.
Dan
Any advice welcome.
Dan
Sure you can do that! I would for sure recommend running a booster otherwise you would get quite a bit of frame flex.
The old style Magura Evo mounts should work on pretty much any trials bike. The wider spacing used by a lot of trials frames to accommodate wide rims means you may not be able to use the new version of the Evo mount which has a brake booster behind as well as in front of the brake. The brake boosters that came with the old style Evo mounts will often rub on tyres wider than 2.3" unless you're really careful in setting them up. Have a look at the magura manual to see the details of the new system (You're not going to get the old system except for second hand I reckon) - see page 6 for some photos:
http://www.magura.com/uploads/media/downlo...rakes__09_E.pdf
Before 4 bolt fittings became standard I used Maguras on single bolt mountings without problems (Except one brake mount pulled off the fork I was using after about 2 years - given my Echo Urban fork snapped in 6 months and that's supposed to be designed for trials that isn't really a bad thing).
With the grabbier brake blocks and ground rims most people run now there may be more risk of things going wrong, but given that the forum isn't full of stories of V Brakes ripping the brake mounts off, Maguras won't be any more damaging as they apply more or less the same force to the same frame mountings.
Edited by psycholist
Mine was terrible, i had the new style versions, and where the frame is a bit too wide, the back booster bends out, and when positioning the clamps and cylinders, one of them would be slanted, and it was a bugger to set up, because you would have to position the cylinders to compensate for the slant of the clamps. I would recommend just getting a good vee with decent pads.
Kieran.
Edited by Julius Czar
