Diy Magura Hs33 Pads.
Brake pads aren't made from rubber. They're polyeurethene (might be the wrong plastic) at any rate, they're actually a polymer. Theres no tutorials as such because its not really cost effective to do yourself unless you're selling them or using them in mass quantities.
The Low Down
Ask Fatmike, Ali C, Heatsink Steve what pad material they use and they wont tell you because they'll have played around with different hardnesses, plasticisers (google it) and materials to get the right stuff. As far as I know, the only way thats done is by contacting a plastics manufacturer and ask for some samples to cut them out of.
Then
Once you get a plastic, simply cut it to the shape of your backings using a milling machine if you have access to one, or if not...er...a knife + file? Might help to take your old pad material out to get shapes + dimensions
Finally
Glue it in and test it. Make sure you remember what plastic type your testing, so that if you want more, you know what type to ask for. Bare in mind suppliers usually sell the stuff in MASSIVE quantities rather that enough for 4 pairs of pads. Mike be able to help you there, give him a PM
Edited by PaRtZ
