muddyfox Posted May 24, 2009 Report Share Posted May 24, 2009 New from Caelifera components...Vee backings and boosters Boosters weigh in at 72 grams. Made from 6061 T6 and hard anodized. 80mm-100mm spacingThe backings are made from 6061 T6 and also hard anodized. Machined to look like the maggie versions only slimmer and the best part is the concave recess in the back that allows the use of a conical washer without it pushing the brake arms way out.(Pictured without the included ss bolt)Post or pm for more details... Quote Link to comment Share on other sites More sharing options...
Connor Powell Posted May 24, 2009 Report Share Posted May 24, 2009 Look really good,Need any testers Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 24, 2009 Report Share Posted May 24, 2009 Potential stupid question: How do the pads attacth to a V brake? Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted May 24, 2009 Report Share Posted May 24, 2009 note: "Pictured without SS bolt"..can't really see the use of the recess with modern v-daptor designs (and the fact that a standard set of spacers give ample adjustment)...how much extra clearance would it even accommodate? Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 24, 2009 Report Share Posted May 24, 2009 Right, time for bed I think! Brain seems to have switched off tonight. Thanks for clearing that up though. Quote Link to comment Share on other sites More sharing options...
basher Posted May 25, 2009 Report Share Posted May 25, 2009 note: "Pictured without SS bolt"..can't really see the use of the recess with modern v-daptor designs (and the fact that a standard set of spacers give ample adjustment)...how much extra clearance would it even accommodate?its a good idea the recess as one of the things i found with my vee set up is when i bought new pads i had to have my adaptors on the wide setting meaning i couldn't run my booster. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 25, 2009 Report Share Posted May 25, 2009 Look good. I know another manufacturer has also been looking at this idea too, shall be interesting to see how both turn out Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted May 25, 2009 Report Share Posted May 25, 2009 Yeah agreed, I think its a good idea and they look swish. V users need more choice for pads! Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted May 25, 2009 Report Share Posted May 25, 2009 not sure about this whole v-brake thing...is it actually any lighter? Quote Link to comment Share on other sites More sharing options...
Matt_Thibeau Posted May 26, 2009 Report Share Posted May 26, 2009 Vee brakes are for sure the way forward Quote Link to comment Share on other sites More sharing options...
Muel Posted May 26, 2009 Report Share Posted May 26, 2009 not sure about this whole v-brake thing...is it actually any lighter?Yeh, but it's only like the difference between rubber grips and foam. Quote Link to comment Share on other sites More sharing options...
muddyfox Posted May 26, 2009 Author Report Share Posted May 26, 2009 For comparison....Caelifera backing with coust pad and 1 conical washer versus Plaz backing without pad and both of the required washers. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 26, 2009 Report Share Posted May 26, 2009 For comparison....Caelifera backing with coust pad and 1 conical washer versus Plaz backing without pad and both of the required washers.not sure about this whole v-brake thing...is it actually any lighter?What 'whole vee brake thing'?I know I for one use vees as I much prefer them to Maguras, it's nothing to do with weight Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted May 26, 2009 Report Share Posted May 26, 2009 (edited) For comparison....Caelifera backing with coust pad and 1 conical washer versus Plaz backing without pad and both of the required washers.call me stupid...but if you don't have space then you wouldn't put those washers in there would you...?edit- btw...I want to say I'm not trying to put the pads down in any way..they're thinner which is great if it helps with clearance. On a similar note..aren't cnc v-backings thinner than magura backings anyway..? Edited May 26, 2009 by Bionic Balls Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 26, 2009 Report Share Posted May 26, 2009 I think the post is meaning that the two required washers are there (concave/conves as in picture) but the pad material is not, just worded a little poorly "Plaz backing without pad and with both of the required washers" Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted May 26, 2009 Report Share Posted May 26, 2009 yeah yeah...what I mean is...if you don't have clearance for them then why would you consider them "required"? I'd put them the other side of the caliper... Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 26, 2009 Report Share Posted May 26, 2009 Oh right, sorry. They're kinda handy in keeping things square to the rim though - you can run them the other side but it's more secure/a tad less sketchy to run them properly Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted May 26, 2009 Report Share Posted May 26, 2009 I am the king of sketch...what I described is how my brake is setup! Been fine though.. Quote Link to comment Share on other sites More sharing options...
muddyfox Posted May 26, 2009 Author Report Share Posted May 26, 2009 I think the post is meaning that the two required washers are there (concave/conves as in picture) but the pad material is not, just worded a little poorly "Plaz backing without pad and with both of the required washers"Yeah, sorry i left out "with" And if you want your pads to hit the rim square then you do need to use the washers.. Quote Link to comment Share on other sites More sharing options...
jambo Posted May 26, 2009 Report Share Posted May 26, 2009 they going to make magura backings the look lush? Quote Link to comment Share on other sites More sharing options...
basher Posted May 26, 2009 Report Share Posted May 26, 2009 yeah yeah...what I mean is...if you don't have clearance for them then why would you consider them "required"? I'd put them the other side of the caliper...they arn't spacers, the washers allow the pads to be set up sqaure to the rim. i supose they are required unless you just let your pads wear 2 an angle Quote Link to comment Share on other sites More sharing options...
Christophe' Posted May 29, 2009 Report Share Posted May 29, 2009 Can I buy the backings only?how muchWhere from?Chris Quote Link to comment Share on other sites More sharing options...
Dang! Posted May 31, 2009 Report Share Posted May 31, 2009 Can I buy the backings only?how muchWhere from?ChrisI imagine Adam will be getting a set to test, in the meantime:from the source or Trails Pads should be ordering some. Quote Link to comment Share on other sites More sharing options...
Dang! Posted June 2, 2009 Report Share Posted June 2, 2009 Hey- sites up finally-www.thecaelifera.com Quote Link to comment Share on other sites More sharing options...
