RossMcd Posted May 24, 2009 Report Share Posted May 24, 2009 Hello!I was browsing around and I came across these! Link!To be quite honest they dont look like they are a good quality backing, and would carbon fiber be an appropriate material to make backings from?Discuss! Quote Link to comment Share on other sites More sharing options...
Synergy Posted May 24, 2009 Report Share Posted May 24, 2009 Hello!I was browsing around and I came across these! Link!To be quite honest they dont look like they are a good quality backing, and would carbon fiber be an appropriate material to make backings from?Discuss!you get many differnent carbon fibre weaves some a lot stronger than others and a lot better quality.it would be hard to figure out what its like, tend to find in low quality cheap stuff there will be little air bubbles. also thats a fake carbon fibre cover over that, carbon fibre raw doesnt look like that. Quote Link to comment Share on other sites More sharing options...
DrDoom Posted May 24, 2009 Report Share Posted May 24, 2009 (edited) http://jforjustice.co.uk/banksters Edited May 24, 2009 by DrDoom Quote Link to comment Share on other sites More sharing options...
Adrian Posted May 24, 2009 Report Share Posted May 24, 2009 you get many differnent carbon fibre weaves some a lot stronger than others and a lot better quality.it would be hard to figure out what its like, tend to find in low quality cheap stuff there will be little air bubbles. also thats a fake carbon fibre cover over that, carbon fibre raw doesnt look like that.yes it is carbon, theyv just cut the shape from a solid rectangle of it. would be alot better if they pressurised carbon into a backing moul, and would also produce a good finish. ill makes some later for a laugh and post pics Quote Link to comment Share on other sites More sharing options...
Guest Posted May 24, 2009 Report Share Posted May 24, 2009 Do trial tech sell wheels over here or on tarty, on line theyre selling a complete set for $150 not bad for trial tech Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted May 24, 2009 Report Share Posted May 24, 2009 (edited) Do trial tech sell wheels over here or on tarty, on line theyre selling a complete set for $150 not bad for trial techOT?!Those backings are so fit!EDIT: Surprised this is the 1st we've heard of them.. Edited May 24, 2009 by Ben John-Hynes Quote Link to comment Share on other sites More sharing options...
Shaun H Posted May 24, 2009 Report Share Posted May 24, 2009 As mentioned above they are produced of CF.It looks to me as if they're produced from thick sheets that have been machined. A bit similar to how brake pads are produced from one big sheet. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 24, 2009 Report Share Posted May 24, 2009 seriously... whats wrong with alu backings? Anyone who says theyre too heavy needs a kick in the balls :/ Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted May 24, 2009 Report Share Posted May 24, 2009 There's no need to try saving weight with bachkings, I think. Cnc backings work just fine for me. Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted May 24, 2009 Report Share Posted May 24, 2009 seriously... whats wrong with plastic backings? Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted May 24, 2009 Report Share Posted May 24, 2009 Would be interesting to know what Steve@heatsink thinks about the use of carbon fibre as a backing. Quote Link to comment Share on other sites More sharing options...
Jason222 Posted May 24, 2009 Report Share Posted May 24, 2009 seriously... whats wrong with alu backings? Anyone who says theyre too heavy needs a kick in the balls :/ Quote Link to comment Share on other sites More sharing options...
mountian goat Posted May 24, 2009 Report Share Posted May 24, 2009 they look a bit sloppy to me. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted May 25, 2009 Author Report Share Posted May 25, 2009 they look a bit sloppy to me.That was my first impression of them! Im not even keen on the o-ring area. They kinda look thrown together and made to no high quality and standards. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted May 25, 2009 Report Share Posted May 25, 2009 they look a bit sloppy to me.To be fair I bet carbon fibre sheet is an absolute bitch to machine! Quote Link to comment Share on other sites More sharing options...
Adrian Posted May 25, 2009 Report Share Posted May 25, 2009 seriously... whats wrong with alu backings? Anyone who says theyre too heavy needs a kick in the balls :/There's no need to try saving weight with bachkings, I think. Cnc backings work just fine for me. if you make all these lil things, topcaps, pads, bar ends, lever blades etc and you could save a fair bit of weight. people buy cf levers and caps so why not pad backingsseriously... whats wrong with plastic backings?theyre shit and snap and felxx crud loads and dont work as good all together. Quote Link to comment Share on other sites More sharing options...
Muel Posted May 25, 2009 Report Share Posted May 25, 2009 You might save 20g over the whole bike. I had carbon lever blades when I had twin hopes on my Kot, they're were shite. Seriously weak, flexed loads and weren't as comfy as the old style mini lever blades.I went over the bars once with the on and crack one of the blades, and it wasn't like it landed on it hard! (Hope replaced it for free though when I sent a load of other stuff in on warrenty. ).I'd tell anyone just to stick to aluminium. Carbon fibre stuff is greatfor stem stacks, singlespeed spacers, top caps etc but I wouldn't trust it for stuff that takes a load of force. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 25, 2009 Report Share Posted May 25, 2009 I also like the way theres no weight in the description.... Quote Link to comment Share on other sites More sharing options...
durkie Posted May 25, 2009 Report Share Posted May 25, 2009 (edited) seriously... whats wrong with plastic backings?they do flex, and everyone wants better brakes. carbon fiber backings absolutely have the potential to be much stiffer and lighter than plastic and cnc'd aluminum backings. whether or not these will actually do it is another issue. as for how they look, you are all just spoiled. every other carbon part you see is just super finished and glossed over. this is what carbon fiber looks like - black. they probably could have done more on the finish, but they are just pad backings and they already cost $37. Edited May 25, 2009 by durkie Quote Link to comment Share on other sites More sharing options...
