Doober1989 Posted May 23, 2009 Report Share Posted May 23, 2009 Heya people I have recently got a new onza blade witch I must say feels very nice to ride but today my hs33 started to seep a little oil from the end of the lever blade opposite end where your fingers sit I wiped it off and a bit later there was some more I'm just wondering if this has happend to anyone else and how can I fix it or do I need to send it back to tartybikes? Thanks Jakk Quote Link to comment Share on other sites More sharing options...
echo rider tom Posted May 23, 2009 Report Share Posted May 23, 2009 if it is were the pipe meets the brake lever than cheek for a splitbut if there is no split then i might be that the pipe has come out a bitso just undo the small bolt with a spanner slowly and push the pipe back in at the same timeand if it moves in then keep pushing and do the bolt back up and then it should be okbut keep checkin it after if it dont work then just leave me a comment Tom Quote Link to comment Share on other sites More sharing options...
snowy= leicester trials Posted May 23, 2009 Report Share Posted May 23, 2009 sounds like your seals going , easyily solvable just buy some seals off tarty Quote Link to comment Share on other sites More sharing options...
onza rider.. Posted May 24, 2009 Report Share Posted May 24, 2009 u might of cort ur hose of the seels have gone or something..look around the brake and found whts wrong with it then bleed it with water Quote Link to comment Share on other sites More sharing options...
