No Hold On My Rear Brake
stunt man t
Try-all pads...say no more.
:huh:
before i changed to set up my old crocos were mint
best pads ive used (Y)
just cant undersstand whate wrong :S
could it be the clamps because its the only thing thats different??
Edited by stunt man t
You could try giving it a fresh bleed in case any air has got in, double check that you have set it up nice and square and if that fails try sanding or filing the tops off the pads or cleaning your rim and pads with some sort of white spirit or along those lines.
Pretty sure you don't use an o ring with them mounts, so they make sure the pads hit square, but never do because rim sidewalls arn't made square, except maybe Ronnies and Echo, pretty sure try-all and trial tech are at an angle, so them mounts are pretty useless, unless they do hit fine, then I have no idea..
i no what you mean mate
my wheel is perfectly square in the frame and the mounts make the pads hit the rim at an angle :S
but good news they have started to bite (Y)
still think the mounts are pretty useless though ;)
recently changed my pads and freshly ground my rear rim :D
fitted some echo tr brake clamps aswell
but all of a sudden the brakes not holding and its bin 4 days :(
what do you think it could be because its doing my head in :lol:
its cause your not running phatpads
Have you taken your tyre on/off or had a puncture after you ground it?
Tyres leave greasy shit on your rim and your brake won't work.
when i ground it i did it the lazy way and just let the tyre down then pushed the tyre away from the rim and put the grinder to it ;)
if you no what i mean???????
the tyres are 4 days old :S
Theres your answer, either the sidewalls aren't flat and parralel or and mounts aren't welded on straight.
