LordMersey Posted May 22, 2009 Report Share Posted May 22, 2009 Just wondering weather to get trialtech or echo rimsWhich best at which?I want your view! Quote Link to comment Share on other sites More sharing options...
Damon W Posted May 22, 2009 Report Share Posted May 22, 2009 iv used bothBoth were around same strengthdunno which is lighter, altho i would say (if you ride street) dont get the front trialtech with sqaure holes, get the circle onesi run trialtech rims front and rear and i love mine, brake is better on the trialtech i think also Quote Link to comment Share on other sites More sharing options...
Adrian Posted May 23, 2009 Report Share Posted May 23, 2009 i think after today no rim iv had before would still be perfectly strait with no flatspots or dents. its a trialtech sport rim, pretty good.and iv used echo urbans till now, and had an sl rim.trialtech all the way, and theyre also lighter. Quote Link to comment Share on other sites More sharing options...
A.Baxter Posted May 23, 2009 Report Share Posted May 23, 2009 I have heard good things from trialtech rims, except for the fact apparently the braking surface is weird:S, apparently the sidewalls areslanted so its weird to set up brake not sure if its true though.Adam Quote Link to comment Share on other sites More sharing options...
Adrian Posted May 24, 2009 Report Share Posted May 24, 2009 I have heard good things from trialtech rims, except for the fact apparently the braking surface is weird:S, apparently the sidewalls areslanted so its weird to set up brake not sure if its true though.Adam bit like try-all rimks but i dnt think theres as much of an angle on the trialtechs Quote Link to comment Share on other sites More sharing options...
