bmxlube Posted May 20, 2009 Report Share Posted May 20, 2009 i see it on ebay does any one know if it is any goodThe B3 2008 20" FRAME FROM ZHI +FORKS + MOE B.B.FRAME- High grade aluminium tubing used throughout- CNC Drop outs for extra durability- Low stand over height- Dedicated 4 Bolt mounts for use with Magura HS33- Extra gussets on top and down tube- Weight: 1850g- Brushed aluminium finish- 6 Month warranty (Against manufacturer defect)Geometry- Wheel base: 1015mm- Rear Chain stay: 358mm- Head angle: 72 degrees- Bottom bracket rise: +55mm- 1 1/8” head tubeFORKSFeatures:- Constructed from U6 Aluminium for maximum strength and weight advantage.- Super thick Aluminium steerer tube.- Straight blade design.- Strong disc mount helps prevent snapping.- Available in 4 Bolt + Disc and V-Brake + Disc.- Satin Black or Pearl White finish.- Star nut fitted.PLEASE CHOOSE, BLACK OR WHITE - V PLUS DISC OR HS33 PLUS DISC.MOE B.B.Precision made ISIS bottom bracket - designed by Trials riders for Trials riders.Large diameter spindle with the races machined and polished into it instead of the standard milled shoulder. This allows the use of 5mm diameter ball bearings instead of 3.75mm employed by other manufacturers. The spindle is SCM15 hardened chromoly steel.Features include:-Sealed cartridge bearings for extra durability.- Weight saving Aluminum.- M15 Chromo hollow steel axle for maximum strength.- 68MM shell width to fit with all popular trials and dirt frames.- 128mm axle is compatible with all ISIS crank sets.- 288G including bolts.- 100’s sold worldwide.- Outstanding value for money. Quote Link to comment Share on other sites More sharing options...
onza rider.. Posted May 24, 2009 Report Share Posted May 24, 2009 u should get it mate .. it nice.. Quote Link to comment Share on other sites More sharing options...
bmxlube Posted May 24, 2009 Author Report Share Posted May 24, 2009 thanks mate im going to Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted May 25, 2009 Report Share Posted May 25, 2009 You're going to buy it, when you asked about if it's good or not in a thread.And you got one reply, saying "u should get it mate .. it nice..".Wow. Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted May 25, 2009 Report Share Posted May 25, 2009 I dont really like them, they look like knock off GU LE's, but if you like it, go for it. Quote Link to comment Share on other sites More sharing options...
bmxlube Posted May 25, 2009 Author Report Share Posted May 25, 2009 its light and cheap thats why im getting it Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted May 25, 2009 Report Share Posted May 25, 2009 its light and cheap thats why im getting itYou only get what you pay for. Why not spend a little more on a more reliable frame, one with a good reputation for being strong, Echo, Zoo etc? Quote Link to comment Share on other sites More sharing options...
bmxlube Posted May 25, 2009 Author Report Share Posted May 25, 2009 because i dont have a job and its hard for me to get money other wise i would get a Echo Team '09 but its £390.51 im having trouble getting £250 Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted May 25, 2009 Report Share Posted May 25, 2009 I might buy one of these at christmas. Quote Link to comment Share on other sites More sharing options...
shnoof Posted May 25, 2009 Report Share Posted May 25, 2009 I like them frames they do look like the gu le but cheaper lol Quote Link to comment Share on other sites More sharing options...
Guest Posted May 25, 2009 Report Share Posted May 25, 2009 LITERALLY- iif you buy a cheap frame it wont last long but if you buy a moderately priced frame it wil last longer, your btter off buying it off here Quote Link to comment Share on other sites More sharing options...
A.Baxter Posted May 25, 2009 Report Share Posted May 25, 2009 LITERALLY- iif you buy a cheap frame it wont last long but if you buy a moderately priced frame it wil last longer, your btter off buying it off here Not strictly speaking the KOXX frames are like £700 and that would deffinatley not last longer than a £300 echo or zoo etc....Anyways i love that frame, it's very nice i would buy it if i were you Adam Quote Link to comment Share on other sites More sharing options...
siede. Posted May 26, 2009 Report Share Posted May 26, 2009 additionaly: I have the Bionic 26" B1. The quality of mine is pretty good, only the 4-Bolt mounts looks a bit frail and the alignment is not that perfect. But no problems so far. Quote Link to comment Share on other sites More sharing options...
eskimo Posted May 27, 2009 Report Share Posted May 27, 2009 I've one of these, second Bionic now. It rides pretty good and strength isn't an issue here. The quality isn't the best, but it isn't the worst. The frame has all the regular features and the quoted geo is right. It's a decent entry level frame. Quote Link to comment Share on other sites More sharing options...
