Front Disc Brake Rubbing On Caliper
alex_trials
Hey,
I've noticed my front disc brake is rubbing abit on the caliper and is making a light grinding sound.
I've tried adjusting the two red wheels either side of the caliper, but that just makes the brake itself really loose and non-responsive.
Is there a way of re-aligning the disc without adjusting how responsive the brake is?
Thanks
Alex
By the sounds of that your talking about a Avid BB7?
What you need to do is back the red dials off all the way, losen the caliper-bracket bolts and move the caliper so the disc rotor is right in the middle of the space.
Then tighen it up, and adjust the red dials so the insode pad is close to the rotor, and the outside to how you like the brake to feel.
What I like to do is loosen the caliper off, where it bolts onto the mounts, then do the red knobs all the way up, tighten the caliper to mount bolts, then loosen the red knobs afew turns. That way I know the pads will be straight etc....
Which way do you turn them, if you are looking forwards (as if you are actually riding) do you turn both wheels forwards or backwards?
Cheers
Ha Ha you bought that bike off owen :shifty:
Heat it up mate realy hot and ride with the brake on for a bit
Or twist the red things on the caliper which is the thing atached on the forks (any way till they are right)
( we all heard the conversation when we were in brum did you do any of the advice owen gave you ^)
:giggle:
Josh.
Edited by joshlyd1
:giggle:
Josh.
Yeah I tried what Owen said, but as I said before, it just made the brakes really loose, I'll give it another go. How do I heat the brakes up?
Cheers
Alex
