Jack Morton Posted May 19, 2009 Report Share Posted May 19, 2009 Basicually i need to no if a Viz Square bottom bracket will fit into my bike Viz square bottom bracketFrame is a Onza t-mag 07Running front freewheel which is a Tensile and Onza muslemen crank arm's i dont no weather it would matter about freewheel and crankarm's but have stated them just incase.Help will be brilliant as i am ordering of tartybike's tommorow. Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted May 19, 2009 Report Share Posted May 19, 2009 Basicually i need to no if a Viz Square bottom bracket will fit into my bike Viz square bottom bracketFrame is a Onza t-mag 07Running front freewheel which is a Tensile and Onza muslemen crank arm's i dont no weather it would matter about freewheel and crankarm's but have stated them just incase.Help will be brilliant as i am ordering of tartybike's tommorow.The only one Tarty hav in stock is the shorter one which is 122.5mm, which you may have clearance issues with due to the front freewheel. Youll be better off getting a 127.5mm BB like the trial tech or something. Quote Link to comment Share on other sites More sharing options...
