Levers For Maggy.
Jackibrap
I find it a bit of a farse bleeding my magura hs33 ive rounded of like 3 levers bleed nipples on the levers. Does anyone know whether a magura julie lever will work on it. Because bleeding with one of them levers would be so easy. open the bleed nipple on the slave, open the top cap on the lever, top it up with fluid pump, hold nipple on the slave, release lever, let go of slave nipple, and pump again then repeat. So please some one help. Thanking you.
How on earth have you rounded them? You must have lamped them up solid, they only just need to be nipped up then a little bit more...
I think it can be done, but as the julie is an open lever it doesn't work very well from what I remember.
well. i dont think i made that bit very clear. i do use the right sized allen key. its just i end up putting the nipple back in on a slight angle. which leads to me more or less de-threading the thread in the lever causing it to leak fluid . fingers crossed i wont do it again.
