Jackk-08 Posted May 16, 2009 Report Share Posted May 16, 2009 Do you need any special tools to fit the cranks back onto a new square taper BB?It's important to get them on straight isnt it after you take them off. Thank you. Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted May 16, 2009 Report Share Posted May 16, 2009 Is it only the cranks your fitting into an already installed BB? I only ask ask the topic asks about fitting the BB itself. If its just the cranks, then line them up and tighten up your crank bolt with an 8mm allen key - nothing special required. its pretty hard not to get them on straight! Quote Link to comment Share on other sites More sharing options...
Jackk-08 Posted May 16, 2009 Author Report Share Posted May 16, 2009 Thanks for that. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 16, 2009 Report Share Posted May 16, 2009 yeah, no special experiance or brain cells needed. just make sure theyre facing 180 degrees to each other and you dont have a kangroo bike Quote Link to comment Share on other sites More sharing options...
