Cranks (front Free Wheel)
Matt Vandart
I'm thinking of changing to front free wheel.
I currently have midleburn cranks which I really like.
I have a monty (FSA) ISIS bottom bracket and my current gearing is 22tothx18tooth
I been looking at the try all ones and also monty ones.
What is the score with bashrings?
Opinions on FFW compatible cranks and gearing would be sooper.
Thanks
Matt
Edited by Matt Vandart
I currently have midleburn cranks which I really like. - If they work...keep them i say
I have a monty (FSA) ISIS bottom bracket and my current gearing is 22tothx18tooth - is the bb 128 mm? if not youll have to change it....22x18 = 18x16ish
I been looking at the try all ones and also monty ones. freewheels? tensiles your best bet by far
What is the score with bashrings? err....They fit between the crank and freewheel...certain bashrings are too thick for certain cranks though
Opinions on FFW compatible cranks and gearing would be sooper. Best I've ever used are echo cnc'd , 18-16 gearing is pretty perfect....18-15 if you like it heavier though
Thanks
Matt
Thanks for your quick replies guys.
Alex, Ive got a 124mm bb I think. are you talking about the Echo SL or just the CNC ones?
Muel I love my middle burns but the problem is with my back hub. I think I need a fixed gear on there so obviously I can't use my middleburns.
It's not the gear size I am concerned about.
Matt
