lukegaigertrials Posted May 14, 2009 Report Share Posted May 14, 2009 hi,i am thinking of buying a brake booster, for my hs33 on my echo team frame, as the brake doesn't fell very nice, and there is lots of flex in the frame,i was just wondering what the difference is between the 2- bolt boosters and the 4-bolt boosters? is there are difference in strength/ efficiently?what booster is best value for money? any help will be greatly appreciated!thanks,Luke Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 14, 2009 Report Share Posted May 14, 2009 a 4 bolt is used in extreme case of flex.if you only have a little flex opt for a 2 bolt Quote Link to comment Share on other sites More sharing options...
selby1 Posted May 14, 2009 Report Share Posted May 14, 2009 tensile boosters ! cheap and very effective wouldn't bother spending more on the rest.mark. Quote Link to comment Share on other sites More sharing options...
lukegaigertrials Posted May 14, 2009 Author Report Share Posted May 14, 2009 (edited) a 4 bolt is used in extreme case of flex.if you only have a little flex opt for a 2 boltim not sure exactly how much the frame flexes but its over a couple of millimeters? would that be 2 or 4 bolt? Edited May 14, 2009 by lukegaigertrials Quote Link to comment Share on other sites More sharing options...
Duncy H Posted May 17, 2009 Report Share Posted May 17, 2009 I'd like to bump this topic to see what people think, I too have an echo team 07 and am in need of a booster. I run phatpads with a nice harsh grind but it doesn't seem to hold well atm because I think of all the flex in my frame. I really like the look and weight of the trialtech 2 bolt booster because of its looks and weight but would it be enough? If not I think i would go with the tensile 4 bolt but what do you think? Quote Link to comment Share on other sites More sharing options...
Jackibrap Posted May 17, 2009 Report Share Posted May 17, 2009 (edited) Ive seen some cases where 2 bolt brake boosters dont clear the back wheel. But thinking about it i recon it was because it was one of those magura race line ones. If you say it has bad flex then a 4 bolt brake booster is now your best trials friend. Make sure you get a strong light one. and make sure it looks good i have a right hefalump on the back of mine its well ugly. Personally i like the echo ones Edited May 17, 2009 by Jackibrap Quote Link to comment Share on other sites More sharing options...
Ali C Posted May 17, 2009 Report Share Posted May 17, 2009 the Trialtech is one of the stiffest boosters around! As much as some 4 bolt boosters! Quote Link to comment Share on other sites More sharing options...
Duncy H Posted May 17, 2009 Report Share Posted May 17, 2009 the Trialtech is one of the stiffest boosters around! As much as some 4 bolt boosters!I think i'll go with that one then thanks for the quick reply. Its a shame the built in boosters aren't so effective. Quote Link to comment Share on other sites More sharing options...
