zoster Posted May 12, 2009 Report Share Posted May 12, 2009 Hi!i am looking to but new disc pads for my front bb7, because the current ones, avid default sintered pads, block my rim when it's high humidity outside , and otherwise don't hold much either. i might have baked them at some point, i'm not sure if i did and i don;t know if this can have anything to do with itanyway, anyone experienced this behaiveur, the pads sticking (HARD) to the rotor in moist conditions?i am interested in buying a pair of disc koolstop disc pads. i heard they are quite great, but they have 2 versions - the common, red backing ones ( i don't know if this is organic compound or what), and sintered ones , which they have goldish backings and are more expensive.did anyone try both or any of them? any input? grab/hold/break-in time/wet conditions ..thanks ! Quote Link to comment Share on other sites More sharing options...
that NBR dude Posted May 12, 2009 Report Share Posted May 12, 2009 I used to use the Red backed ones in my Magura Martas years ago. They worked really well in all conditions, but I wouldn't say they were that much better than standard pads on a clean, well maintained and set up disc. Quote Link to comment Share on other sites More sharing options...
zoster Posted May 12, 2009 Author Report Share Posted May 12, 2009 I used to use the Red backed ones in my Magura Martas years ago. They worked really well in all conditions, but I wouldn't say they were that much better than standard pads on a clean, well maintained and set up disc.coolt, thanks. i think i'll give them a try Quote Link to comment Share on other sites More sharing options...
nek0 Posted May 13, 2009 Report Share Posted May 13, 2009 I'm not sure why they would cause to lock up but at least with sintered pads, they're generally designed for long term braking like XC & DH. Another reason why organic brake pads are excellent for short term braking like for trials. Sintered pads also have more metal compared to any organic or semi-metal pads so they will wear down your rotor much faster.Just a thought... Quote Link to comment Share on other sites More sharing options...
