Scott Gibbs Posted May 11, 2009 Report Share Posted May 11, 2009 Im curious to know the different set ups different riders have on thier bikes, ie different levers, hoses, pads ect. I would like to know so i can get an optimal set for a rear magura, and dont end up buying stuff the looks good but works like absolute shite! All in put is appreciated. Thanks guys Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 11, 2009 Report Share Posted May 11, 2009 (edited) I have a hs22 lever, braided hose, no booster, koxx brown pads, worn grind.It's not a fantastic brake, I think it has to do with how the pads have worn and the toss lever I've got. I want an 04 levera, and thankfully I know where to get one Water bled, too. Edited May 11, 2009 by Bruce Lee Quote Link to comment Share on other sites More sharing options...
trials_pimp Posted May 11, 2009 Report Share Posted May 11, 2009 Ive got a New Style Magura, with standard Hoses, Magura Oil Bleed, TNN CRM Pads, Tensile Offset Mounts and an Echo 4 Bolt Booster.I love my brake, work amazing, never slips and holds super well. Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted May 11, 2009 Report Share Posted May 11, 2009 TNN CRM PadsAre they as good as the old compound?Iv'e got front and rear 05+ HS33, water bleeds, Coust in the rear and echo pads on the front.Ginger Allen Quote Link to comment Share on other sites More sharing options...
andyb Posted May 11, 2009 Report Share Posted May 11, 2009 At the moment im using standard hosing, 4 finger lever blade(came with it) and croco browns.Amazing brake. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted May 11, 2009 Report Share Posted May 11, 2009 My mom has 04 Maggies raceline red Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted May 11, 2009 Report Share Posted May 11, 2009 New stlye maggie. Royal blood bleed. Standard hose. No booster with coust pads and dust seal removed off master piston. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 11, 2009 Report Share Posted May 11, 2009 hs33 new style lever standard hose water bleed magura cnc lever.....2 bolt trial tech booster heatsink cnc red pads hench grind Quote Link to comment Share on other sites More sharing options...
Muel Posted May 11, 2009 Report Share Posted May 11, 2009 09 lever with GU lever blade, filed down the lever stop and filed the lump off for the blade bolt and replaced with a filed down nilock nut, metal TPA.Monty splitter with standard Maggy hose.Two M8/M6 slaves with the line from each splitter going into a nut and shroud. (Much harder to kick the lines off than with barbs).Mixture of water and pro-cool bleed.Tensile mounts filed down so my two bolt Echo booster can be bolted straight onto it with using spacers. Much stiffer and no loss of bite.Heatsink Yellow material in Phatpads backings.Can't get it working how I want though. The lever piston sticks in the body and the pads don't hold well enough. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted May 13, 2009 Author Report Share Posted May 13, 2009 Been looking on tartybikes recently and found the echo tr levers, are they any good they look awesome but i would rather get some feed back before a purchase! Was also thinkin about heatsink cnc coust pads. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 13, 2009 Report Share Posted May 13, 2009 As of today I'm rolling on:Deng CNC lever with '08 Echo bladeStandard magura hose and cylindersFinest Devonshire water bleedKoxx Brown padsAs of tommorow I'll have TNN pads. Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted May 13, 2009 Report Share Posted May 13, 2009 05 maggie, standard hose, Onza Pro-Series pads, Trialtech booster and maggie oil. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted May 13, 2009 Author Report Share Posted May 13, 2009 05 maggie, standard hose, Onza Pro-Series pads, Trialtech booster and maggie oil.does fluid really make that much difference? And whats a water bleed? Or am i just being thick? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 13, 2009 Report Share Posted May 13, 2009 Fluid makes a difference in the feel of the brake. Oil = thicker, and therefore slightly harder to pull at the lever. Waterbleeds are just running water instead of oil in the brake. Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted May 13, 2009 Report Share Posted May 13, 2009 Are they as good as the old compound?Aparently, they are the old compound... Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted May 13, 2009 Report Share Posted May 13, 2009 Aparently, they are the old compound... Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted May 13, 2009 Report Share Posted May 13, 2009 Will just the material be available does anyone know? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 13, 2009 Report Share Posted May 13, 2009 Yes it will and no, no-one knows when. Quote Link to comment Share on other sites More sharing options...
Dannoo Posted May 13, 2009 Report Share Posted May 13, 2009 Standard magura HS33 cylinders and lever, with a clean swedish water bleed.Blue RockPads and a 4 Bolt Adamant booster, on a GU LE 08 frame. Quote Link to comment Share on other sites More sharing options...
Ryan-Trials Posted May 13, 2009 Report Share Posted May 13, 2009 05+ Maggie with Zoo lever blade, water bleed with cnc cousts and echo cnc mounts and titainium bolts, no booster Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted May 14, 2009 Author Report Share Posted May 14, 2009 Standard magura HS33 cylinders and lever, with a clean swedish water bleed.Blue RockPads and a 4 Bolt Adamant booster, on a GU LE 08 frame.But surely a water bleed cant be good for the magura internals like the seals and pistons and wont it leak because water is thinner than oil? Quote Link to comment Share on other sites More sharing options...
trials_pimp Posted May 14, 2009 Report Share Posted May 14, 2009 No a water bleed works fine. The seals on the brake are good enough, they dont leak. Some people do have the brakes freeze in the dead of winter, if bikes are left outside/in cold sheds.Water can move faster than oil so the brakes feel lighter and more responsive, but over time water compresses so you have to bleed them more, or you notice slack in the system, whcih you can take up with the TPA for a while.There is nothing wrong with a proper oil bleed, if done right will work well for ages. Mines been going over a year now without fault. Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted May 14, 2009 Report Share Posted May 14, 2009 I won't go back to water for a long time - it caused too many problems and meant there was a lot of maintenance. Theres no point bleeding so often if you don't need to! I use royal blood now which isn't significantly thicker than water so doesn't make a real differance in feel - just means i won't have to bleed my brake for a couple of years...........which is nice! Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted May 14, 2009 Author Report Share Posted May 14, 2009 No a water bleed works fine. The seals on the brake are good enough, they dont leak. Some people do have the brakes freeze in the dead of winter, if bikes are left outside/in cold sheds.Water can move faster than oil so the brakes feel lighter and more responsive, but over time water compresses so you have to bleed them more, or you notice slack in the system, whcih you can take up with the TPA for a while.There is nothing wrong with a proper oil bleed, if done right will work well for ages. Mines been going over a year now without fault.I might have to give it a go would it be ok to use a water bleed with a braided hose do u reckon? Quote Link to comment Share on other sites More sharing options...
