Tarty Bikes Hope Pro 2
is it anything like the new style Pro 2 ? are they reliable ? do they skip ? would a Q/R adaptor thing fit ?
Edited by Nick pyke :)
Are you proposing that Tartybikes had Hope make a differently designed hub just so they could put their name on it? Why would they do that, and why would Hope do that, when the original pro 2 works fine as it is?
I've had one - they're just pro 2's with Tartybikes written on the hubshell. Never had any problems with it - it's identical to the other one I got from crc, but with the additional writing.
sorry Muel :$ got distracted by Rumples reply. its not mine yet but im not sure wether to buy it (on the cond that he buys kings) or just look out for a Hope Pro 2 trial.
Generally speaking if a Pro2 works as it should, all is well. Mine started skipping recently and Nick Wood immediately said it would be a snapped spring. Fortunately the jammy b*****d was right, so it cost me about £2 to fix.
Parts are really easy to get hold of and are dead cheap, and if you crack the hub shell or strip the drive ring or snap an axle, they tend to just warrenty them straight away.
Clean it out when you get it though, the grease slowly works out of the bearings and gets into the pawls/springs. They also tend to get a lot louder with a fresh clean and some nice thin oil in there. (Y)
I just used 3 in 1, works perfect.
Nope, just a soft ended hammer and some wooden blocks to rest it on.
to smash the inner parts out ? sorry sounds unlcear to me lol
the ones with tartybikes on are far stronger spin well loads faster and are louder........they also make u ride better just because tartybikes is all over it :P
im messing.....:D
:D if only!
