Guantanamo Posted May 4, 2009 Report Share Posted May 4, 2009 Anybody had any experience facing their brake mounts for disc brakes? How did you go about doing it, or should I get it done in a bike shop?ThanksAdam Quote Link to comment Share on other sites More sharing options...
Muel Posted May 4, 2009 Report Share Posted May 4, 2009 You either need a facing tool or you need to get a shop to do it for you.If you're handy with a file you can get it fairly close, but you need to make sure that the rotor is absolutely flat and true first. Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted May 4, 2009 Author Report Share Posted May 4, 2009 You either need a facing tool or you need to get a shop to do it for you.If you're handy with a file you can get it fairly close, but you need to make sure that the rotor is absolutely flat and true first.If i get a shop to do it for me what do i need to take to them. Just my forks? Quote Link to comment Share on other sites More sharing options...
Muel Posted May 4, 2009 Report Share Posted May 4, 2009 Yeh just the forks, the tool fits into the dropouts and uses a wierd milling bit type thing to cut a tiny bit off the disc mount and make them flat. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 4, 2009 Report Share Posted May 4, 2009 If they're anything other than an ISO mount you'll have to check with them what tool they have, as the Hope one doesn't fit non-ISO. Most stores now carry a Hope one as they're so much cheaper than the competitors.Tartybikes can face forks for you, and do +20/+30 mounts too. Quote Link to comment Share on other sites More sharing options...
