Luke_zoo Posted May 3, 2009 Report Share Posted May 3, 2009 (edited) I've got to subs but not in a box as I took them out of the sub box and I have four 6x9's But I was woundering if I would be able to build a box them ply wood and fiberglass over it? for a smmoth finish then spray them?But where would the wires run to?How would I get it to run form the amp into one wire to the cd player?Has anyone done this before?Help please Edit : with the sub amp and speakers it works out at 1300watts of sound is that bad or good lol? Not very good with sound systems as I'm building it all up to put into a car. Edited May 3, 2009 by :)zoo! Quote Link to comment Share on other sites More sharing options...
george_seamons Posted May 3, 2009 Report Share Posted May 3, 2009 I've got to subs but not in a box as I took them out of the sub box and I have four 6x9's But I was woundering if I would be able to build a box them ply wood and fiberglass over it? for a smmoth finish then spray them?But where would the wires run to?How would I get it to run form the amp into one wire to the cd player?Has anyone done this before?Help please Edit : with the sub amp and speakers it works out at 1300watts of sound is that bad or good lol? Not very good with sound systems as I'm building it all up to put into a car.Firstly, ditch the 6x9's if you have a sub, they simply don't work well together. Put the sub (or subs) in a box, and wire them to the amp. Then wire the amp to the battery and headunit.Sounds like you need to do some research before you go crazy. Look on google for boot builds or something.And just for the record, 1300w's of power doesn't mean anything really. Doesn't make it a good or bad systen. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted May 3, 2009 Author Report Share Posted May 3, 2009 Firstly, ditch the 6x9's if you have a sub, they simply don't work well together. Put the sub (or subs) in a box, and wire them to the amp. Then wire the amp to the battery and headunit.Sounds like you need to do some research before you go crazy. Look on google for boot builds or something.And just for the record, 1300w's of power doesn't mean anything really. Doesn't make it a good or bad systen.Ah right cheers Problem wil be solved in no time. Quote Link to comment Share on other sites More sharing options...
The Hitcher Posted May 3, 2009 Report Share Posted May 3, 2009 As said already, ditch those 6x9 straight away. Buy a component set and put them up front and just have the subs in the back. Quote Link to comment Share on other sites More sharing options...
