Disc Brakes?
they just dont provide enough hold.....inteh same way that a hope mono mini doesnt or an m4
What he said
The bigger the disc rotor, the more powerful.....a rim is essentially a massive rotor which is barely affected by grease/dirt, you can't grind a disc, you can't use tar. If it's not powerful enough you're just stuck with it.
A disc will never ever hold as tight as a rim brake, You need to ride a bike with a good magura on it, then you wont want a disc.
Leon
