Freewheels?
Billiboi
at the moment i currently have a onza t bird crank with a fixed sproket on. so i have a rear freewheel, if i get new cranks can i run a freewheel on front and back?
if not what do i need to change?
cheers all
You can use double freewheel, if you dont really want your teeth. The engagment is utter crap.
You could use a front 18tooth freewheel and I think (correct me if I am wrong) oddesy make 12tooth freewheel. But you would have to get a new hub aswell. :)
