jack101311 Posted May 1, 2009 Report Share Posted May 1, 2009 my maggy mounts rounded of and my brake doesnt work aswell as it should. Quote Link to comment Share on other sites More sharing options...
JackC123 Posted May 1, 2009 Report Share Posted May 1, 2009 my maggy mounts rounded of and my brake doesnt work aswell as it should.that post you did there was no elp at all:/If you gave us abit more info, we could help. Which mount is it, tried a booster bolt? There are alot of things you could try like helicoiling etc etc. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted May 1, 2009 Report Share Posted May 1, 2009 Drill through the forks or frame?Whitch ever one it is and put a bolt all the way through the holes and but a lock bolt on the over end and bobs your uncle you can ride agen or you can drill the mounts out and tap them to M6 or drill it out to M6 and heilcoil ?But the bolt idea is what I would go for my self I know some one on the forum has done it and it was a good idea. Quote Link to comment Share on other sites More sharing options...
jack101311 Posted May 5, 2009 Author Report Share Posted May 5, 2009 Cheers lad. Get on to that a.s.a.p. Quote Link to comment Share on other sites More sharing options...
weirdoku Posted May 5, 2009 Report Share Posted May 5, 2009 Best is get them helicoiled, drilling to M6 and stripping that means drilling out to even bigger size holes which you'll probably strip again...Helicoils done right are hard to damage. Quote Link to comment Share on other sites More sharing options...
Adam Griffiths Posted May 6, 2009 Report Share Posted May 6, 2009 If you buy some Liquid metal paste and put some in the hole where the mount bolt goes then buy a tapping tool and re-thread it. this should sort out your problem. Quote Link to comment Share on other sites More sharing options...
