Bleeding Disk Brake?!
Fvil
Turn the lever on the bar so the reservoir is level - when you replace the reservoir cover roll it onto the surface of the oil to make sure no air is trapped in the reservoir.
Push the pistons in the caliper back as far as they'll go and remove the brake pads before starting the bleed.
Bleed from the lowest point in the brake to the highest as this helps drive air out of the system.
