Andrew Willis Posted April 30, 2009 Report Share Posted April 30, 2009 (edited) Hi guys.Got this profile hub and the non driveside bolt is siezed Anyway to remove this siezed bolt off the axel ?cheers Edited April 30, 2009 by Andrew Willis Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted April 30, 2009 Report Share Posted April 30, 2009 Cover it in Wd-40. Then tighten up the other side into a frame or forks as tight as you can. Then try your best to undo the siezed side.Dont blame me if you snap the bolt though Quote Link to comment Share on other sites More sharing options...
