Ben-Shogun gimp Posted April 27, 2009 Report Share Posted April 27, 2009 hey guys,my left crank keeps coming off when i ride, I've tried tightening the bolt but didn't work.its a square taper and i think that the taper has gone.. ive only just bought them and cant afford new ones.does any body now how to sort this out, anything even if its stupid i just need it to stay on for a while until i can buy a new oneBen Quote Link to comment Share on other sites More sharing options...
bigamac Posted April 27, 2009 Report Share Posted April 27, 2009 Erm... what cranks are they?But you have probably rounded them off.Cut a coke can up into small strips. Place them onto the BB axle and wedge the crank arm on and tighten up. Should work.I could explain in more detail but i can't be bothered to i'm sure someone else will. Quote Link to comment Share on other sites More sharing options...
Jitters Posted April 27, 2009 Report Share Posted April 27, 2009 Yep, just like he said. Search for a similar topic. It's been covered lots and I've used the soda can trick myself with good results.. Let us know how it turns out! Quote Link to comment Share on other sites More sharing options...
dirty-boi Posted April 27, 2009 Report Share Posted April 27, 2009 I agree with Tappets and Bigamac.What crank is it? make, model, etc.Just so we know to avoid them if they break that quick. Quote Link to comment Share on other sites More sharing options...
Lord Banks Posted April 27, 2009 Report Share Posted April 27, 2009 It's going to be the bolt that holds the crank on the axle which must be coming loose, the threads must have gone, you could try some loctite on the threads but on something as high-load as a crank this probably won't last for long.If you're lucky, it might just be the crank bolt thread that's stripped, you can pick them up for a couple quid from your lbs. If not, you'll need a new crank arm. Quote Link to comment Share on other sites More sharing options...
Jitters Posted April 27, 2009 Report Share Posted April 27, 2009 It's going to be the bolt that holds the crank on the axle which must be coming loose, the threads must have gone, you could try some loctite on the threads but on something as high-load as a crank this probably won't last for long.If you're lucky, it might just be the crank bolt thread that's stripped, you can pick them up for a couple quid from your lbs. If not, you'll need a new crank arm.That's a possibility too for sure. Good point. Just be sure not to use the maximum strength loctite (or similar brand). Go for the medium duty stuff. The maximum strength is as advertised and could very well lead to the crank bolt becoming a permanent part of your bottom bracket. I know from experience. Quote Link to comment Share on other sites More sharing options...
sstein Posted April 27, 2009 Report Share Posted April 27, 2009 It's going to be the bolt that holds the crank on the axle which must be coming loose, the threads must have gone, you could try some loctite on the threads but on something as high-load as a crank this probably won't last for long.If you're lucky, it might just be the crank bolt thread that's stripped, you can pick them up for a couple quid from your lbs. If not, you'll need a new crank arm.Not quite, when the crank arm rounds it means the interface between crank and bb does not have a tight fit, this allows a small amount of movement, this pushes against the bolt and causes it to loosen. The more the bolt loosens the more the crank wobbles. The best temporary fix is to use a strip of coke can like already has been said. Quote Link to comment Share on other sites More sharing options...
Ben-Shogun gimp Posted April 27, 2009 Author Report Share Posted April 27, 2009 Erm... what cranks are they?But you have probably rounded them off.Cut a coke can up into small strips. Place them onto the BB axle and wedge the crank arm on and tighten up. Should work.I could explain in more detail but i can't be bothered to i'm sure someone else will.their onza muscleman cranks and its not te bb thread as ive only just bought a new 1 as i thought that was the problem by cutting strips of can???ben Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 27, 2009 Report Share Posted April 27, 2009 Blue locktite on the threads? Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted April 27, 2009 Report Share Posted April 27, 2009 coke can jobbo works a treat on bb......yeah take a coke can cut strips up....lay them on the bb axle put your crank back on tighten up the boltDAVE Quote Link to comment Share on other sites More sharing options...
Ben-Shogun gimp Posted April 27, 2009 Author Report Share Posted April 27, 2009 i can't see how that works.. wouldnt the strips of can just come out when puttin the cranks back on? Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted April 27, 2009 Report Share Posted April 27, 2009 (edited) i can't see how that works.. wouldnt the strips of can just come out when puttin the cranks back on?Im telling you it works.......other members are as well take the adviceits baisicly adding more material for the crank arm to sit on Edited April 27, 2009 by Dave Anscombe Quote Link to comment Share on other sites More sharing options...
Ben-Shogun gimp Posted April 27, 2009 Author Report Share Posted April 27, 2009 Ok cool il give it a go tomorrow and post back to tell you how i got on or if i need some helpthanks guys if this works you've saved me allot of moneyoh actually one last question will a coke can work fine or do you suggest another one?Ben Quote Link to comment Share on other sites More sharing options...
Lord Banks Posted April 27, 2009 Report Share Posted April 27, 2009 Tizer cans are much better because they're lighter.Buy one of these:-http://www.tartybikes.co.uk/product.php?pr...category_id=100£11.74 is nowt. Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 27, 2009 Report Share Posted April 27, 2009 Tizer cans are much better because they're lighter.Buy one of these:-http://www.tartybikes.co.uk/product.php?pr...category_id=100£11.74 is nowt.Lighter being thinner? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted April 28, 2009 Report Share Posted April 28, 2009 Lighter being thinner?ULTIMATE n00b comment? Quote Link to comment Share on other sites More sharing options...
trials ryan Posted April 28, 2009 Report Share Posted April 28, 2009 hey guys,my left crank keeps coming off when i ride, I've tried tightening the bolt but didn't work.its a square taper and i think that the taper has gone.. ive only just bought them and cant afford new ones.does any body now how to sort this out, anything even if its stupid i just need it to stay on for a while until i can buy a new oneBenhave you checked the thread that happend to me once just brought a new crank. Quote Link to comment Share on other sites More sharing options...
bigamac Posted April 28, 2009 Report Share Posted April 28, 2009 Well you said there muscle man cranks. I got them at the moment and I am using the bodge.It will work if you do it right. It shouldn't push the coke can out if the strips are long enough it should make it a VERY tight fit. Quote Link to comment Share on other sites More sharing options...
dirty-boi Posted April 28, 2009 Report Share Posted April 28, 2009 Lighter being thinner?RAOTFLSHALBOWCO"Rolling around on the floor laughing so hard a little bit of wee came out" Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 28, 2009 Report Share Posted April 28, 2009 ULTIMATE n00b comment?If you had kept your head in your arse for a little bit longer I was waiting for a reply. If it's thinner its just got more chance of stripping again, hence why you use a coke or even pepsi can which is thicker.RAOTFLSHALBOWCO"Rolling around on the floor laughing so hard a little bit of wee came out"Go away n00b. Quote Link to comment Share on other sites More sharing options...
dirty-boi Posted April 28, 2009 Report Share Posted April 28, 2009 Go away n00b.WTF? and you are? Quote Link to comment Share on other sites More sharing options...
trialschallenger Posted April 28, 2009 Report Share Posted April 28, 2009 the coke can or for arguements sake a can in general(i profer red bull as it gives you wings and helps you hop)and a spotta blue locktite on the thread it will last a fair amount of time when it wears loose again pop another bita can in it Quote Link to comment Share on other sites More sharing options...
A.Baxter Posted April 28, 2009 Report Share Posted April 28, 2009 their onza muscleman cranks and its not te bb thread as ive only just bought a new 1 as i thought that was the problem by cutting strips of can???benI had the same problem with my set i ended up getting new cranks and bb which in the long run turned out better But i dont really have any help, the only way this can have happened is by riding with the crank loose, square taper cranks even when just slightly loose are very easy to do this with.Adam Quote Link to comment Share on other sites More sharing options...
dirty-boi Posted April 28, 2009 Report Share Posted April 28, 2009 Another solution if its really bad is copper pipe.Trim a length, then using metal cutters slice it in half on one side, flatten it out into a sheet and use the same strip technique.It works exactly the same, but better than using loads of can strips if really bad. Quote Link to comment Share on other sites More sharing options...
Ben-Shogun gimp Posted April 28, 2009 Author Report Share Posted April 28, 2009 well guysi tried it and it worked sort of.. its not coming off and its not wobbling as much so il go back to it when i have more time tomorrow and try several layers see if that will worksthanks for the advice guysBen Quote Link to comment Share on other sites More sharing options...
