guuuuuuuuu leeeeeeeee Posted April 25, 2009 Report Share Posted April 25, 2009 is there any way of botching vee brake springs if there not long enough mine curently have more selotape holding it on than anything ive every used before Quote Link to comment Share on other sites More sharing options...
jambo Posted April 25, 2009 Report Share Posted April 25, 2009 if its the spring i think your talking about a couple of small cable ties might do the trick a tad neater. Quote Link to comment Share on other sites More sharing options...
guuuuuuuuu leeeeeeeee Posted April 26, 2009 Author Report Share Posted April 26, 2009 ok thanks Quote Link to comment Share on other sites More sharing options...
trialschallenger Posted April 26, 2009 Report Share Posted April 26, 2009 i tend to sway more on the side of a small jubelee clip stronger and therefore a bit safer than a cable tie Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 26, 2009 Report Share Posted April 26, 2009 You could also just throw in some different springs if you can find some that are suitable Quote Link to comment Share on other sites More sharing options...
sstein Posted April 26, 2009 Report Share Posted April 26, 2009 Why are they not long enough? If you mean that they have occasionally jumped out, then increase the tention and maybe put a thin ziptie around the arm if it persists. Quote Link to comment Share on other sites More sharing options...
