Chris King Help :(
rider_01
Are you sure everything is tight?
Assuming you have a CK BMX:
Take the wheel out, take the bolts off the axle, and undo the axle locking collar - you will need a 3/32" allen key to undo it but if you don't have one use a 2 or 2.5mm and be very careful, you only need to undo it a little bit so it's not pinching anymore, then unscrew it and take it off, and you should be able to take the axle out. Check that everything is sitting properly in the hub, if you need to you can take the driveshell off too (by turning it slowly and pulling, be careful with this too!). This will allow you to check the bearings to see if they're all okay. If they are, and the axle is, then...
To put it back together, put the driveshell on, turning it clockwise as you push it in (to my knowledge). Put the axle all the way through (I'm pretty sure it only fits in one way, so it's pretty simple, goes in the same end it came out), screw the axle locking collar back onto the axle, and make sure it's snug, spin the hub, it should spin freely and not move side to side at all. If this is the case then tighten up the 3/32" allen screw, and you're good to go, if it's still wobbling then something is up, and I suggest you don't ride it and send it up to Tarty for a service.
If it's a 135mm HD hub, the instructions are identical, if it's a 135mm QR hub, then the axle adjuster doesn't have an allen screw on it, it just threads on.
I'm sorry if these instructions aren't 100% correct as I'm doing it from memory, but as long as you don't try and tear the thing down to component pieces they're pretty easy to get apart.
