Need Help Hs33 Cross Over Pipe Disaster.
Jack Morton
Right i will get straight to the point today i broke my cross over pipe and have a perfectually good other one the only problem with it is that i overtightened it once and snapped the bit of which goes into the caliper bit. I want to no if it is possiable to put one of the fine screw in bit's into the fine cross over. As i need it for tommorrow and If i order one it wont come until tuesday. So need it to hold out until next week some time.
Help would be apprishiated.
Jack.
Jack.
I would borrow you one if I had one.
Someone lend this guy a crossover!
Doesn't matter anymore fixed
Just cut the end of , Cut the remaining pipe of the screw in bit , Got some hot water so it would be easier to slide the crosspipe to the screw bit , Put cross over in a vice , Hammered the screw bit in to it
I dont even think i need a new cross over it looks really strong.
Jack.
Jack.
I would still replace it, as it will fail, its all about when!
Probably whilst your back hopping an 8ft wall, not only will you get wet, you will break your bloody neck.
Is it really worth the risk for the sake of a couple of quid.
