trialsmax04 Posted April 25, 2009 Report Share Posted April 25, 2009 My magura hs master cylender looks like its leaking. Dont really want to shell out for an 05 one so:1. can i just replave the seals?2.where can i get the seals?3.is it worth it?cheersMax Quote Link to comment Share on other sites More sharing options...
gu trials Posted April 25, 2009 Report Share Posted April 25, 2009 mine looked like it was leaking and it was but it was because the little nut thing had come undone a little bit and the water started coming out. have u tightend the nuts ? hope i helped Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 25, 2009 Author Report Share Posted April 25, 2009 Im affraid its not leaking from one of the hose fittings. It is comming from where the leaver pushes the piston. I bled it yesterday and was good and then went shit after 10 mins. Bled it again this morning, and now its shite.... Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 25, 2009 Author Report Share Posted April 25, 2009 Please help! I need either the plastic seal or a complete lever body....Any one got one floating around?max Quote Link to comment Share on other sites More sharing options...
trialschallenger Posted April 25, 2009 Report Share Posted April 25, 2009 how about poping the lever piston out and giving it a good cleen and a relube,once youve popped it out if the seal looks ruined then look at getting a new one Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 25, 2009 Report Share Posted April 25, 2009 He has a point, if it doesn't work, taking it out to see how broke it is isn't going to cause it to get any worse.If you don't want an 05 lever, maybe see if anywhere has a new 04 lever? Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 25, 2009 Author Report Share Posted April 25, 2009 Hi,I cannot get the piston out. Ive used a compressor on the hose fitting and it just wont fully pop out. Im not botherd if i get an 05 or 04 lever, im just skint at the moment.Max Quote Link to comment Share on other sites More sharing options...
Netherking Posted April 25, 2009 Report Share Posted April 25, 2009 ring magura, they have a 5 year leak proof warrenty that might interest you? thats if you got receipts Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 25, 2009 Author Report Share Posted April 25, 2009 ring magura, they have a 5 year leak proof warrenty that might interest you? thats if you got receiptsNow that is guting!!! I got the bike second hand so i have no reciepts..... Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted April 25, 2009 Report Share Posted April 25, 2009 Now that is guting!!! I got the bike second hand so i have no reciepts..... nooo, it'd be void anyway if youve bled it with waterjust use a 2mm allen key and push the piston out through the hose connection hole always works for me....if all else fails, ill have a look at it for you sometime Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 25, 2009 Author Report Share Posted April 25, 2009 Cheers alex...I will have a go on monday, as im trialing tomorow on the beta.Id really quite like a newer 05 style lever. Im going to post in the wanted section now.cheersmax Quote Link to comment Share on other sites More sharing options...
