trialschallenger Posted April 22, 2009 Report Share Posted April 22, 2009 just put my new chain on(kmc kool chain) and after every half rotation of the cranks the chain rides round the sprocket on the middleburns and gets caught up,it looks like the chain is too wide is there any way round this? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 22, 2009 Report Share Posted April 22, 2009 If it's a Middleburn ring, you can often flip them over to put the teeth an extra mm or two from the bash. The pins of a thick chain can get caught on the bash edges so this might be the case. Otherwise either running a thinner chain, machining the bash down a touch, or popping a few washers between the ring and bash may help.Then again, it may just be a case that everything needs to bed in a little more Quote Link to comment Share on other sites More sharing options...
trialschallenger Posted April 22, 2009 Author Report Share Posted April 22, 2009 that sounds like the kiddy there,and i think it is an original middle burn round so ill go flip it roundcheers Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted April 22, 2009 Report Share Posted April 22, 2009 i had the same problem, before i noticed that the pins on the split link poke out more the one side...spit the chain, turned around no probs! Quote Link to comment Share on other sites More sharing options...
manuel Posted April 22, 2009 Report Share Posted April 22, 2009 which KMC ? even with the narrow it still rubs a little ... Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted April 23, 2009 Report Share Posted April 23, 2009 mines a k710 Quote Link to comment Share on other sites More sharing options...
