austen Posted April 21, 2009 Report Share Posted April 21, 2009 I bought a pro II in january, and since then ive gone thro 6 chan tugs. The hub itself is fine, never skipped or anything like that, but it just won't stay in place(i have horozontil dropouts). If i dont have a chain tentioner on the drive side, i can't even cycle a couple of metres without the hub slipping in the dropouts and my wheel getting slammed into the frame. Even if i do have tentioners on my bike, they last about one ride, because they just like explode because the hub puts so much pressure on them to keep the wheel in place. Does anyone have a solution to this?(and yes, the hub is tightened as much as it can)cheers, Austen x Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted April 21, 2009 Report Share Posted April 21, 2009 8mm allen head bolts should help a bit Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted April 21, 2009 Report Share Posted April 21, 2009 happend to me all the time .......i got the 8 mm head bolts from tarty........also what tensioner do you use.......i recomend the 74 kings if you dont already have one Quote Link to comment Share on other sites More sharing options...
austen Posted April 21, 2009 Author Report Share Posted April 21, 2009 (edited) 8mm allen head bolts should help a bithappend to me all the time .......i got the 8 mm head bolts from tarty........also what tensioner do you use.......i recomend the 74 kings if you dont already have oneWill the 8mm allen head bolts stop it from moving, all together, or will i still need tugs?I use chain tugs as the hub is on my dmr :/Are these the bolts? boltsOr are they just the standard 6mm allen head ones Edited April 21, 2009 by austen Quote Link to comment Share on other sites More sharing options...
