Andrex Posted April 21, 2009 Report Share Posted April 21, 2009 Got a brand new chain, fitted it as you normally would. But it doesn't seem to be sitting on the teeth on the front chain ring. The chain links seem to be too long for it and won't sit on. It just skips along the top of the teeth. Does this mean I need a new bash or a different chain?The chain is a trialtech kmc kool and its on a middleburn super pro bash.Heres some pictures to help.Cheers. Quote Link to comment Share on other sites More sharing options...
andyb Posted April 21, 2009 Report Share Posted April 21, 2009 You bought the wrong pitch of chain by the looks of it. Quote Link to comment Share on other sites More sharing options...
shamus Posted April 21, 2009 Report Share Posted April 21, 2009 does look like the pins might be catching on the bash and its holding the links away from the cog, try spacing the cog out if there is enough thread.or if its modstock it may be an issue of the gearing and chainstay length meaning the chain is a awkward length (happened once or twice while playing with ratio's on the bmx) Quote Link to comment Share on other sites More sharing options...
Muel Posted April 21, 2009 Report Share Posted April 21, 2009 Theres only one pitch of chain for bikes? And those bashes can take a KHE collapse so it's not the width thats the problem.The teeth on the bash look knackered though, maybe they've worn too much with a stretched chain, and the gap between the pins on the new chain is shorter.Looks like you might have to get a new bash to me. Quote Link to comment Share on other sites More sharing options...
Andrex Posted April 21, 2009 Author Report Share Posted April 21, 2009 Theres only one pitch of chain for bikes? And those bashes can take a KHE collapse so it's not the width thats the problem.I was using a KHE before this chain and it was fine, well apart from stiff links and snapping the spacers in te centre and the fact I had to use a grinder to get the chain off lool.Its a shame the middleburn 16th bashes are all one piece Quote Link to comment Share on other sites More sharing options...
LEON Posted April 21, 2009 Report Share Posted April 21, 2009 Skanky ring syndrome. Your old skanky chain worked with your old skanky ring because they were both skanky, it's 1 or the other, replace the lot or nothingLeon Quote Link to comment Share on other sites More sharing options...
Simpson Posted April 21, 2009 Report Share Posted April 21, 2009 Skanky ring syndrome. Your old skanky chain worked with your old skanky ring because they were both skanky, it's 1 or the other, replace the lot or nothingIs that the technical diognostic of it Leon?Just grind the bash down, or get a skinnyer chain Quote Link to comment Share on other sites More sharing options...
Tall_Rob Posted April 21, 2009 Report Share Posted April 21, 2009 God Andy... i tolf/explained this to you yonks ago when you were thinking of a new chain.You need a new front sproket as Leon talks about.Try one of these >>>> Bashguard for Middleburns Quote Link to comment Share on other sites More sharing options...
Muel Posted April 21, 2009 Report Share Posted April 21, 2009 It's not the chain width that's the problem though Mike, mine fitted a collapse in fine, even if that's the widest Kool you can get I don't think it's any wider than a collapse. Quote Link to comment Share on other sites More sharing options...
LEON Posted April 21, 2009 Report Share Posted April 21, 2009 Is that the technical diognostic of it Leon?Yea i used wiki for that one!Andy stop being a cheap b*****dLeon Quote Link to comment Share on other sites More sharing options...
Simpson Posted April 21, 2009 Report Share Posted April 21, 2009 Yea i used wiki for that oneIt just make me laugh cos' it reminded me of the time i pushed my sisters motorbike round to the repair shop after a crash.Mechanic, "Ah na mayte thats dead"Me, "What you you mean dead?"Mechanic, *looks at me like im stupid* "I mean its DEAD you KILLED it"haha Quote Link to comment Share on other sites More sharing options...
Andrex Posted April 21, 2009 Author Report Share Posted April 21, 2009 Try one of these >>>> Bashguard for MiddleburnsHmm good call, I think that is on my to get list now Quote Link to comment Share on other sites More sharing options...
