ONZA_TRIALS Posted April 20, 2009 Report Share Posted April 20, 2009 hi im am wondering how to fix a buckled wheel ? Quote Link to comment Share on other sites More sharing options...
ONZA_TRIALS Posted April 20, 2009 Author Report Share Posted April 20, 2009 no answers ? Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted April 20, 2009 Report Share Posted April 20, 2009 You got a spoke key? if not smash it back straight lol. Quote Link to comment Share on other sites More sharing options...
ONZA_TRIALS Posted April 20, 2009 Author Report Share Posted April 20, 2009 lol yeh i have a spoke key do i just tighten them up mate Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted April 20, 2009 Report Share Posted April 20, 2009 Good. http://www.trials-forum.co.uk/wiki/Truing_a_wheel Quote Link to comment Share on other sites More sharing options...
ONZA_TRIALS Posted April 20, 2009 Author Report Share Posted April 20, 2009 cheers mate Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted April 20, 2009 Report Share Posted April 20, 2009 cheers mateNo Probs Quote Link to comment Share on other sites More sharing options...
dirty-boi Posted April 20, 2009 Report Share Posted April 20, 2009 It depends on what you mean by buckled.If its like a banana then bin it.Other wise, strip the rim from the spokes and put it in the freezer.Ive never tried it with a girthy rim but it usually works well on bmx rims and will quite often pull quite a lot of tow out.Make sure its not fractured before you try.If its fractured also "bin it".Oh and pump those tyres up! Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 20, 2009 Report Share Posted April 20, 2009 True it?And before you true it, you should let down the tyre (less pressure on the spokes/rim), you can even witness it changes becuase next time you let down the tyre then pump it up sometimes the wheel needs trueing again. Quote Link to comment Share on other sites More sharing options...
ogre Posted April 20, 2009 Report Share Posted April 20, 2009 kapow idiot freindly guide Quote Link to comment Share on other sites More sharing options...
Daveee Posted April 20, 2009 Report Share Posted April 20, 2009 Check the wiki for your trialsing needs Quote Link to comment Share on other sites More sharing options...
jakejp94@hotmail.co.uk Posted April 21, 2009 Report Share Posted April 21, 2009 Where the wheel is buckled use a spoke key to tighten it and the rim should pull back in. Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 21, 2009 Report Share Posted April 21, 2009 Where the wheel is buckled use a spoke key to tighten it and the rim should pull back in.You have too loosen the oposite spoke though, as it is just putting alot of tension on the other side. Quote Link to comment Share on other sites More sharing options...
