Magura Hs33 Problem
Andrew Willis
Hi guys
so i got this new frame and put my back brake on.
Gu clamps
Tensile booster
HS33
After rebleeding the brake around 3-4 times while its been off the bike i finally put it back on this morning.
The leaver still comes to the bars :|
not sure what the problem is or how to fix it !
cheers
Andy
i had a similar problem, to get round it i completly flushed the system threw and lubed everything up then bled it off the bike and pumped the brake for a while taping it (keeping the lever up high) turned out to be some trapped air in the slaves i assumed because after bleeding it a couple of times it returned to normal
