Msn's A Douche.
Hannah Shucksmith
Basically, since last Friday I've been trying to sign in using the latest MSN messenger and I've had a load of error's come up. I've been searching the internet all day looking how to solve the problem; I've uninstalled and reinstalled the programme twice, done the command prompts I've been told I should try, checked all my settings and firewalls and such and still no avail! The error code has changed and I'm currently on:- "Error code: 81000306". Wondered if anyone else is having the same problem / had the same problem and what they did to solve it. I'm fed up with using Meebo...
Edited by Hannah Shucksmith (:
Sorry, that's all I could think of. :(
I had a right load of trouble a few months ago trying to get it sorted, in the end I reinstalled everything though because I had a problem with something messing up my installs every few months, so I replaced the motherboard, ID cables and hard drives with ones from an old PC I got from my Dad's works.
Might be worth considoring wiping it and starting again, it's a pain in the arse but it's worth doing IMO. Just make sure you back everything up first if you go for it. (Y)
This topic is now closed to further replies.
