Very Stupid Question
37H4N™
A mod is a 20 inch wheeled bike and a stock is a 26 inch wheeled bike
Hope this helped.
no its not you can have 26" mod
its the drop on the frame where the back wheel goes in if its vertical its a stock and if its horizontal where you use a chain tug then its mod
:D Ben(not the correct terms but...)
So your saying the 20" Atomz is a stock simply because it hasn't got horizontal dropouts?
It's to do with wheel size and rear hub spacing.
26" wheels, 135mm spacing - stock
26" wheels, 118mm spacing - mod-stock
20"/19" wheels, 118mm spacing - mod
Edit: 118mm spacing is more common on mods and 135mm on stock.
Edited by Headley
