gaztrials. Posted April 14, 2009 Report Share Posted April 14, 2009 hi there i have a zona zip and its a bit on the heavy side would it weaken my frame if i cut a hole in the head tube ???thanks gaz Quote Link to comment Share on other sites More sharing options...
TJ. Posted April 14, 2009 Report Share Posted April 14, 2009 Yes because you are removing metal, but if you want to risk it go ahead but i wouldnt remove any metal from my frame.Cheers TJ Quote Link to comment Share on other sites More sharing options...
gaztrials. Posted April 14, 2009 Author Report Share Posted April 14, 2009 hi there i have a zona zip and its a bit on the heavy side would it weaken my frame if i cut a hole in the head tube ???thanks gaz ok thankyou Quote Link to comment Share on other sites More sharing options...
indianatrials Posted April 14, 2009 Report Share Posted April 14, 2009 I wouldnt worry about weakening that frame, its strong as heck, even though it is heavy. How are you planning to cut the hole?Cheers Quote Link to comment Share on other sites More sharing options...
Muel Posted April 14, 2009 Report Share Posted April 14, 2009 It will make no difference at all, it only saves about 25g, and when the frame itself is 2300g it really doesn't matter.If you got a lighter frame you could easily save 500-1000g. Quote Link to comment Share on other sites More sharing options...
Ali C Posted April 14, 2009 Report Share Posted April 14, 2009 I have NEVER seen any frame fail because of a hole in the headtube. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted April 14, 2009 Report Share Posted April 14, 2009 ive cut out the head tube of my onza t-pro and various other parts(cut off bash gaurd mounts and use a bash ring instead) etcand its made a HUGE diference Quote Link to comment Share on other sites More sharing options...
gaztrials. Posted April 14, 2009 Author Report Share Posted April 14, 2009 ok thankyouthanks for the advise mate im not to sure on what im going to cut the hole with yet Quote Link to comment Share on other sites More sharing options...
