Painted Rims
orange*zero
Get them treated well with nitromours. That will strip the old paint off completely. Watch it though it burns!
Then you can either prime, undercoat and top coat yourself or if you want something that is going to last and that has a flexible finish you could have it powdercoated.
Personaly I would have it powdercoated, it doesn't cost much. Bob jackson cycles are very cheap, they quoted me £130 for a full frame in metallic finish and they also pick up and deliver back to you.
Hope this helps.
If you take your time to prepare the rim properly(sand/mask) then use a quality paint, with a few layers of undercoat it should last ages.
Make sure the surface is dirt/oil free and has a good key and your away!
I'm sure you can get paint that once sets is like plastic in texture and what not. that might work? :ermm:
You could get it sandblasted? just a thought. :turned:
I have done it recently with one of my bmx rims all i did was:
Sand / key it all down with sand paper (until you can see small scratches in the paint and most of the paint is off)
Spray it 3 times with primer
Spray about 4 light coats of a paint of your choice
Thats my SSS rule for spraying
Hope i have helped
Josh
Hope i have helped
Josh
If you want a good finish you have to sand between coats. Gradually using finer and finer sandpaper. Wet and dry 1500 grit is what you should end up using.
Hi...
My front rim is painted on my bike.. It was done properly and looked great, but after a while it did start to flake off and look shabby. On the back rim, however, it did not flake off. I think the main reasons for this are:
1)The paint on the front was too thick
2)The front rim had painted sidewalls, as it is a disc wheel, whereas the rear had a grind. The sidewalls on the front took more damage maybe?
3)It had side drilling on the front, And air got behind the faint ad this made it flake off?
So, I think if you do it properly, don't do the paint too thick, and grind it once you are done (Only if Maguras are in use) then you will be fine.
Also, Don't use a front Onza rim because I think these are the oly ones with side drilling in them :P
