Hope Mono Trial Disc Brake
crispyboy
do your pistons on your caliper return ? have you got a leak anywhere ?
if your pistons return ok and you have no leak you will be best to strip down your lever and check the internals for help you can use hope direct http://www.hopegb.com/voir_mini06.html
The pistons on the caliper do not return
I dont have a leak for sure
That would be your problem then, best go for a rebleed and inspect your pistons.
I had a problem with my front one last year, where one of the piston's popped out to far I could actually see them behind the pad when I looked straight down on my caliper.
I then pressed them back in to find that the problem continued, eventually I found out that they need to pressed in perfectly flush to ensure they don't pop out again.
(Y)
