Magura Hybrid
trialschallenger
Have they changed/Is the C2 lever suitable for use with mineral oil, or is it only for DOT fluid? What's the piston size too?
I suspect the seals will be ok with mineral oil, betting the piston size will be far too small though.
nope, mineral oil wrecks the seals (fast too) and the piston is far to small, the brake will pull to the bars with even the stiffest set-up plus you will have to set the pads soo close to the rim your brake will almost always rub.
I tried it years ago, its not worth it.
