joshlyd1 Posted April 9, 2009 Report Share Posted April 9, 2009 What is the standard magura rim brake mount allen key bolts width because i am building a custom 2 bolt brake booster for my onza mod been as i have tried nearly every 2 and 4 bolt boosters on the market please help ...josh Quote Link to comment Share on other sites More sharing options...
Krisboats Posted April 9, 2009 Report Share Posted April 9, 2009 Clearly the standard size isn't what you need. If standard sized boosters don't fit your frame you might be better off measuring your frames width, none of us can tell you that. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted April 9, 2009 Author Report Share Posted April 9, 2009 yeh i am making the booster to fit i just dont know how big the bolt holes should be ? Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted April 9, 2009 Report Share Posted April 9, 2009 I made my self a custom brake booster once out of some old clutch plates out of my motorbike it was really strong aswell. Unfortiaonally i eventually snapped it. Quote Link to comment Share on other sites More sharing options...
MAX (M.A.D) Posted April 9, 2009 Report Share Posted April 9, 2009 (edited) The standard magura bolt size is 5mm.Hope this help, Max. Edited April 9, 2009 by MAX (M.A.D) Quote Link to comment Share on other sites More sharing options...
Krisboats Posted April 10, 2009 Report Share Posted April 10, 2009 yeh i am making the booster to fit i just dont know how big the bolt holes should be ?Not meaning to sound like a cocky twat but you asked this question on here, which took 7 hours and 21 minutes to get a correct reply, rather than just measuring the hole that's in your frame or failing that one of the bolts you've used on these other boosters you've tried.Unless you've not got/can't work a ruler you've probably spent more time replying in here than it would have to just go and measure it for yourself. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted April 10, 2009 Author Report Share Posted April 10, 2009 im illiterate takes me ages to do stuff but thanks for your replys reel help Quote Link to comment Share on other sites More sharing options...
